Tire size question
Ga usa
My cars tire size is 235/50r17 I want to use cooper cs5 gt but it's made in 235/55r17 could that size work on the rim? Or would there be issues with the rim and clearances.
The bigger question is: How much room is under the febders? Is the tire going to rub?
For that we need to know the year, make, and model of the car - and even then, we might not be able to figure this out. To my knowledge, no one publishes a list showing what fits inside the fenderwells.
Originally Posted By: Kawiguy454
the tire will fit on the rim and will be slightly narrower and taller. Im guessing less then .5 inch
Why would it be narrower?
^ Exactly my thinking. It is still a 235 section width.
It is actually 0.93in taller. That's pretty significant in my opinion.
Originally Posted By: stephen9666
What is the car in question and what is the OE speed rating?
Yes, I would be more concerned about the tire meeting the correct specs. Usually one size up(in secdion width or aspect ratio) will fit a wheel well.
Who knows? Not enough information.
What you can rely on, however, is the following:
- Acceleration will be slower
- Braking distance will be longer
- Speedometer will no longer read correctly
- Odometer will no longer record accurately
- Gas mileage might get better, but then again, it might get worse
- Tire pressure recommended on the door jamb will no longer be correct
Other than that, the tire will fit on the rim - good news!
HTH
I think the general rule of thumb is still that you don't want to go much above 3% of increase to the wheel diameter. The 3.5% increase likely won't make a difference to the wheel control electronics if it fits...although it's still an unknown. Much above that and all bets are off.
I upsized the tires on my car to a 205 vs. the 195 OEM and it actually corrected the speedometer / odometer versus the OEM size. I extended my warranty to what it should be....
2013 Matrix was 205/55/16/6.5" wheel, now 225/45/18/8" wheel.
2013 2500 GMC, was 265/60/20 8.5" wheel, now 275/65/20 9" wheel.
(Believe me, you don't want my full list of o/s tire and wheel combinations)
AS long as you have 1/2 inch of clearance at full crank,
a one inch taller tire will fit without rubbing.
....And so what if it rubs at full crank?
I don't guess anything is wrong with the ultra tires I just thought the GT tires would be better for rural roads.
Car they will be going on is a 2014 Ford Fusion se both of the rear tires have developed flat spots on the treAd making the car bouncy.
