Originally Posted By: dslofti
My local dealer does it with motorcraft oil and filter for 29.95 I can do it myself with mobil 1 for about 33.00 I know motorcraft is a syn blend which one would you do? Thanks
While it's under warranty, stay with the dealer. If you do it yourself, make sure you document your changes (receipts, records of date/mileage/oil used/filter used) in case there's a warranty issue and the dealer gives you a hard time. Plus at that price, you're not saving much doing it yourself IMO.
