Originally Posted By: surfstar
Eww. 20" and lightweight?
I'm guessing its for a 1999 Trooper?
Stick to what you have and save your cash. Bigger wheels are heavier. Lighter ones are expensive. You have a problem in that you want the opposite of each. Good luck in your search.
But seriously 16" is fine. Your tires are cheaper and more comfy. You can't talk about "handling" performance in your desires to run dubs on your Trooper. No. Just no.
Okay, just looking at your other topics too - first car? You seem teenaged-overly-enthusiastic. Seriously, save your $ and don't buy big, shiny, "rims". Or a filter bypass setup. Etc.
If you don't have something helpful, constructive, or positive to say. Then please just keep your comments to yourself.
I only said I would be willing to go up to twenty because a buddy of mine has a 2012 sierra with some wheels that are very lightweight....however the offset is wrong. And as I said I'm not even sure I would go up to twenty.
I'm not looking for bigger wheels for performance. I'm not looking for lighter wheels for performance. This is my road trip vehicle. It is not my daily driver. I want to take some weight off the wheels to improve gas mileage. I also want new wheels to improve the stance of the vehicle. And if I'm looking for wheels to improve stance, I might as well go lightweight anyways...Since that's what I want!
I wanted a bypass filter because Troopers burn oil and I wanted to add another quart to the system, and keep the oil clean to prevent the oil burning from getting worse.
This is not my daily driver and when I do drive this its for long trips. (Ex: Texas to Nevada)
This is not my first car, nor am I a teenager.
