Wondering if my brake booster could be going or if I have a vacuum leak? Brake pedal feels softer and hearing a hissing sound when I depress the brake. Hissing stops after pedal is depressed about halfway. But if I depress the brake 1/4 of the way and hold it there with foot it will continue to hiss like air is blowing somewhere. I need to have family member hold brake in so I can figure out where it is coming from. I have also noticed that when I stop the truck with pedal depressed, put into park and turn key off the brake pedal forcefully pushes back out but maybe it has always done that and I just never noticed. Seems to stop ok although a couple times here in the driveway it seemed like brakes didn't work well and then all of a sudden were "grabby". Sorry for the poor explanation but something is different. I don't drive the truck often. Fluid level may be a touch low so plan to fill the master.
