Originally Posted By: 440Magnum
My biggest concern with what you posted is that you got into a coolant over-temp situation. That's indicative of just flat-out not enough cooling capacity. The best oil in the world won't help that- so you need to make sure the coolers (oil, coolant) can shed enough heat to keep everything in the green for a whole session.
As for oil, I agree with those who suggest a 0w40, like Mobil 1. It has a great reputation in hard usage, and its close enough to the factory specified 5w30 that its not going to cause any issues. I saw your concern about it being a 0wXX- don't worry about that. I always tell people that to really understand a multi-grade oil they need to think exactly backwards from what is intuitive. Think of the oil's thickness AT OPERATING TEMPERATURE (say 230-250F), and that's what the number after the "w" is talking about. At full engine temp, M1 0w40 is a 40-weight oil, just like a 10w40 or a 15w40 would be. Now think what happens as the engine cools down- that's what the number before the "w" tells you. A 15w40 and a 0w40 are the same thickness when hot, but the 0w40 doesn't thicken as much when it cools down, so it flows better and is a better lubricant when you first start the engine up. Its already more like it will be when its hot.
The nice thing about modern synthetic multi-grades is that they can get that wide rating spread and more nearly constant thickness without a lot of additives like older oils use.
Given how hard you obviously use this car, it might also be worth looking at some of the more expensive "boutique" oils that tolerate high temperatures well in the 30- and 40-weight range. Redline comes to mind because of their more heavily ester-based base oil, but quite honestly Mobil 1 is comparable to most of the other boutique blends in 0w40. I wouldn't necessarily make the same claim about Mobil 1 10w30 and 5w30, or Pennzoil Ultra 10w30 and 5w30, though. M1 0w40 seems to be a real standout in the "off the shelf" product range. Pennzoil's closest (IMO) would be their Euro 5w40. I'm ambivalent about their 0w40 (even though it was designed specifically for one of my vehicles) because it is a bit lower on some of the old-school classic anti-wear additives than M1.
PS- its also possible that 10w30 is a really bad choice here, but its hard to say since most big oil suppliers won't go into a lot of detail about their chemistry. Reading the tea leaves (oil analyses and MSDS's) does hint that some makers actually use lower quality base stock oils in 10w30 since they don't need the high inherent viscosity index, and can hit the 10w30 spec with a poorer base stock and a modest dose of VI improvers (non-lubricating polymers that coil and uncoil with temperature changes to regulate the thickness of the fluid). That approach results in an oil that is more prone to viscosity breakdown under high stress than an oil with a higher quality base stock and fewer VI improvers. I'm not sure that's the case with PP 10w30, but I have just developed a general skepticism toward 10wXX grades anymore. Much more R&D is has been poured into 0wXX and 5wXX oils over the past 20 years, and 10w30 in particular is sorta along for the ride since no manufacturers spec it anymore.
I agree with 440Magnum. I'd run some Mobil 1 0w40 in it.
Also you mentioned a larger oil cooler available, I'd be doing that right now.
