Originally Posted By: Rand
The subaru crush washers actually crush. I just go till they stop crushing.. no leaks yet. I use a 1/2" drive ratchet and with my angle laying under the car you cant really get a ton of force on it. Worked fine on the old car too.
At least my 2015 was upgraded to the 17mm drain plug
the 14mm potmetal drain plug in the 2011 was terrible. I rounded it off on the first oil change from the factory where it was super tight and painted on. I then replaced it with a new one..
Later I purchased as special 6point 14mm socket that applied torque to the flats of the bolt.
Now I know why I prefer to change my own oil. A 1/2" socket wrench and getting on it like you say is nuts. One of these days your going to strip out a pan. I just lightly tweak the bolt, probably no more than 5-10 ft lbs. Never have seen an issue and its always tight when I go to change it.
