Hi. I read a post here concerning 5w20 oil in Explorers. It mentioned timing chain issues. After 1,200 miles of having 5w20 installed in my 05 Eddie Bauer, powered by a 4.0 with 160,000 miles, I ended up with a timing chain issue and entire top end of the engine. After a 300 mile trip at highway speeds is when the noise was obvious. The weekend before my wife said she heard a noise but I figured it was the radio.
The morning after the trip, when it started cold it sounded like there was no oil on the lifters. I have recordings of it taking 5 minutes to quiet down. Prior to that the engine never made any noise even starting at -25°F. As soon as I found out that it had the 5w20 I changed it back to the 5w30 but it was too late. In fact, prior to changing it at one point in the trip when it was starting hot I thought my battery was dying or my starter was dragging but apparently the engine was binding. When the engine was torn down there was a timing chain issue as well as some lifter damage. There were posts stating that the oil pump would not build enough pressure with the 5w20. I found a TSB that referenced the use of 5w20 in 01 and 02. TSB 2-1-9. I could not find any other documentation concerning this. Can anyone comment on this? Can anyone point me in a direction to find additional information concerning issues with 5w20 in 4.0 engines. Thank you for the help. Matt
