Thanks for the assistance guys,
My 07 Focus has a persistent squeak when releasing the brake pedal. I recall this same issue with my 97 Escort that also had rear drums. The problem was from the rear shoes dragging on the backing plate when the pedal was released.
Today I took the car into a nearby shop to have them grease the contact points. Sure enough, they called me shortly after dropping the car off to say that they were unable to remove the drums, fearing that they'd damage the wheel bearings in the process.
So what's the best way to effectively remove them? Heat? Or should I just pony up the extra cash for rear bearings and drums (while I'm at it) and just be done with it?
Your assistance is appreciated
