I am presently looking for a cheap non-propelled push mower to mow some nasty areas that I do not wish to mow with my good Lawn Boy.
Looking on CL and I found a Troy Bilt (which I usually would not consider) mulching mower with a 6.5 Briggs. It is not running and is cheap. In the description it states that there is a part which was superglued together and the mower ran until the glue joint failed. I inquired as to what the part is, and the seller does not know the name of the part, but described it as a "plastic pipe."
Question: What kind of a part resembling a plastic pipe would be on a 6.5 Briggs?
