The blower motor in my Kizashi recently stopped working (luckily we're having reasonable weather here...not too hot or humid). After doing a little online research I figured it was the blower resistor (which I read is a notorious failure part in these cars and other Suzuki models). The resistor was expensive ($148 shipped) and I replaced it 2 days ago (I checked the fuse which was good and noted that the compressor for the a/c would come on when activated but no fan activity...hence my diagnosis of a blown resistor).
The blower worked after replacing the resistor and I thought I fixed the problem. It stayed "fixed" for a day...blower stopped working again yesterday.
I did notice that the blower seemed to be "surging" when in use and I didn't feel that there was as much airflow for the various speeds (particularly on high) as before (this is a climate control system with a multi-speed blower). I'm leaning toward a bad blower motor which is blowing the resistor...(in which case I should have replaced both of them as has been recommended by a few with the same issue).
Does it seem likely that the blower motor is shot and is tripping the resistor? My options are to order a blower motor (used ones available online for cheap) and a new resistor, install both and see if that corrects the issue or take it to a dealership (far from here) and get a proper diagnosis?...and outrageous repair estimate.
I planned to take the car to a dealership I'm familiar with in mid-August when I take my vacation (will be in the area) for the "spider web" (spiders may make webs somewhere in a vent tube for the charcoal canister, I believe) and gear shift (may come out of park without depressing the brake pedal) recalls I've been notified need to be performed. The dealership is 450 miles from where I currently live and I'm familiar with them...they've worked on the car before for routine stuff when it was newer...seemed pretty good (for a dealership anyway).
In any event, I'll need to fix this sooner than later (can't use the car much if it gets hotter/more humid). Airflow while moving without the blower is pretty feeble.
I'm inclined to try replacing the blower motor and another resistor and see if that does the trick.
