A New Oil from Pennzoil
SOUTHERN CALIFORNIA
Hey All you oil gurus,,,,
Has anybody tried that new oil made from natural gas????
Just curious and thought that I would ask.
All the best,
THUMPER>>>>>>>>>>>>>>>>>
A bit noisier engine in my IS vs M1 5w30, but expected due to 1 cst lighter oil. Otherwise the same as any other oil.
Yes, lots of people have as it's not that new anymore.
What do you want to know?
II was curious how the #'s stack up against some of the known favorites, was wondering if anybody has done a UOA yet??
I saw it on the shelf at Walmart, if they would have had it in a Xw-40 I might have given it a try.
Just browse the UOA section. Any of the recent PP/PUP UOAs are likely to be of the GTL version. But don't expect to see miracles from a UOA.
They do make a 5w-40 which is what I'm using in my 530i. Walmart does not carry it though.
By the way, why is this posted in the Motorcycle UOA section??? Are you looking for a motorcycle oil specifically?
I was thinking of trying it in my V*,,,usually I run Rotella T or T6, used to use Mobil 1 15w-50, and have also used Redline 15w-50.
Thanks for taking the time to weigh in,
If it's a shared sump application, I would stay away from any 5w-40 oil. GTL or not, time and time again they have shown to quickly shear out of grade in such applications as a result of being loaded with VIIs.
I'd stick to something in 15w-40 or 10w-40 grade.
