Oldmoparguy1
Thread starter
Originally Posted By: HTSS_TR
When temperature changes from 70 to 100 tire pressure is up 3 PSI, the tires face afternoon sun have much higher temperature up to 20-30 higher, therefore those tires can have as much as 5-6 PSI above morning pressure before driving.
I would check pressure in the morning and don't have it more than placard, then afternoon it will be no more than 2-3 PSI above placard.
Yes! I have a good gauge. Thanks. Good place to start.
I was thinking rotate tires front to back.
Ok, last update. The tires run smooth, no symptoms of out of balance. This has been an odd experience.
What did you do to cure the problem ? Adjusted pressure or rotated front to back or both ?
Actually, nothing. I recorded tire pressures cold & hot, morning & afternoon for several days. I never found anything that related to the situation. I've been driving and fixing cars since I was 12. I'm now 78. I dono..
