Originally Posted By: steve20
Originally Posted By: toyota62
When i changed the engine oil in 2AZ-FE engine i have noticed engine oil is getting very hot even after short time at idle.(too hot to touch.)Older 5sfe engine doesn't. Then again 5sfe engine has an oil cooler.Not sure 2AZ-FE has an engine oil cooler or not.
Ah hah! that is why, despite the sludge those old 4cyl Camrys are still around--an oil cooler on a low output 4 cyl. I had a 92, and believe me, it was low output
The 4cyl is not a sludger, do some research.
