Originally Posted By: tony1679
My mom just bought a new Hustler mower. 23HP Kawasaki, 52" deck, $2999. Awesome rig. She has turned to me for care and advice. There are several oddities, but one stands out. It came with a Hustler manual that states to change oil at 40hrs. There was also a Kawasaki manual, which called for 100 hours. What gives?
It has a filter and 2.2qt sump...
Also, The mower accepts a range of oils from 5W-20 to SAE40 (with SL being the most recent spec
) . From what I understand SAE30/10W-30 is ideal. I'm not a fan of SAE30/40. I am using a full synthetic 5W-30 in my Briggs, and it is specifically labeled acceptable. Neither of the manuals mentions synthetics at all, much less any being acceptable. Is there any reason not to use a full synthetic 5W-30 here as well?
Last, what filters are good (and preferably cheaper) besides the Kawasaki. No junk filters, just looking for easier availability (Wix?). Cross-referencing this filter has been confusing so far. Thanks in advance!
I got a Gravely ZT XL 48 3 years ago with a Kawasaki FR730V engine. I hear what you are saying have the very same thoughts. I don't care for straight weight oils, but i can understand why people use then, because its cheap and it won't shear like conventional multi-weight oils will. There a lot of people on here that like diesel rated oils. I sometime think when it comes to motor oil recommendations for small gas engines, it seems there baseness with the engineers. Kawasaki did not recognized the use of synthetic oils in there engines like B&G did. I went out on a limb and used 5w30 synthetic oil in my Kawasaki. Bought some when Advance Auto were running a specials. Also, just remember your newest API ratings are backwards compatible, so I wouldn't worry about using the newest rating. I have used a Purolator PureOne PL10241 and a Mobil 1 M1-102 oil filter. You can use these numbers to cross reference if you have the room for the filters. If not, Lawn_Care gave some good advice. Just remember it will take a little more oil for a larger oil filter. If your concerned about warranty, I would use a 10w30 synthetic oil if you want to go synthetic. Use whatever auto oil filter that works since Kawasaki gives no specs. on what oil filter to use. I pretty sure your mom's new mower has the maintenance free Hydro Gear transmissions. When I bought mine I got the ones that weren't, cost more, but I least have some that I can change the oil. I used 15w50 synthetic in my Hydro Gear ZT2800.
