Personally, I don't think there's a definitive way of saying that the biggest contributor by far to fuel economy is oil viscosity. Independent of the GDI ( which the Mirage doesn't have ), the biggest fuel saving elements on my subcompact ( as documented by the manufacturer ) are the EPS and the "smart" alternator...both of which will provide greater fuel savings than what grade of oil I'm using.
The Mirage has a variable displacement oil pump that matches the oil flow with the needed oil pressure. This reduces the parasitic load on the crankshaft and may ( in the right circumstance ) give you the same fuel savings as going with a lower grade oil. Tires and a lower drag coefficient of the car might even offer more fuel savings than dropping an oil grade. It's not exactly a static environment.
