Please note that a Piston Driven AR-15 with the capability of going full auto is a different beast than a AR-15 without the capablilty of going full auto.
If you are speaking about using a AR-15 like a Squad Automatic Weapon, and placing 100's and perhaps 1000's of rounds downrange in a short amount of time, then yes, I'd agree that a piston driven weapon system is the way to go.
In this case I'd prefer a full length operating rod that is directly attached to the bolt carrier so that there is extra mass and reduces the cyclical rate of fire.
However, if you don't have a "fun switch" or you do have a "fun switch" and you aren't planning on running it like a SAW.
Then I don't see where the argument is valid.
The H&K 416 was designed as a smaller lighter rifle, much like the M4 carbine, but with better sustained fire capabilities.
For most of us little guys, who don't have a government sized budget to buy ammo, the gas tube cuts down on weight, reciprocating parts, and cost.
I like my gas tubes. I've never had an issue.
If I want a short piston weapon system I have an SKS.
If I want a long piston weapon system I have an AK.
Personally, I really like my AR the best. I find it to be more refined, and even though I put mine together using well researched but budget parts myself I've never had any of the issues anyone speaks of.
The idea of a Piston Driven AR is interesting.
But for my application, I don't see the advantage.
