I need to cut shower door metal bottom and top channel. The instruction says to use hacksaw with 32TPI blade. I don't have one and don't want to buy one. I have no problem buying relevant blade for portable 5" circular saw, or for 6amp reciprocating saw or for oscillating multi-tool or for a Dremmel. Which would be the best and most effective solution?
I had been doing some work with 1x6 PVC board and a cut which takes less than 15 seconds using the circular saw, took inordinate amount of time with reciprocating saw or the oscillating multi-tool. So my preference is to find the correct 5" disc from the 18V circular saw if there are no gotchas.
