Originally Posted By: boraticus
The only problem I see is wasting expensive synthetic oil when a good HDEO would suffice at a fraction of the cost. I've run Rotella in many, many applications from motorcycles to lawnmowers forever and it has performed as intended.
If you have no plans of extending the oil change duration, what's the advantage?
You can throw your money away by under-utilizing synthetic oil. The choice is yours.
Regarding going the full 100 hours, I would. I've been doing that for years as well in my riding mowers (Kawasaki and Honda engines). Pull the dipstick and check the oil condition. In my engines, it takes quite a while for the oil to show signs of discoloration. Just remember to do your first oil change after 5 to ten hours of use. Thereafter, follow the manual's instructions.
Very well said, Sir.
I tend to think many BITOG'ers overdue things way too often and change oil long before needed - especially regarding OPE. Rotella or DELO is all i've ever ran in OPE, scooters, bikes, etc. and have never had an oil related failure.
I do admit to changing oil in my scooters and bikes more often than some manufacturer's recommendations, but that is only on models without oil filters.
I do, and will continue to, always make sure and change oil filters at the same time as the engine oil. I just can't convince myself to put fresh oil in an engine with a dirty oil filter. Silly I know, i'm more than sure the oil filter has plenty of capacity left. For me it's the principle.
