Originally Posted By: turtlevette
The "shear" off the shaft argument would be under more extremely viscus conditions. Have you ever seen a drop of oil move around in a hot non stick pan? A lack or break in adhesion.
What does a teflon coated frying pan have to do with a journal on an IC engine ?
You flounder with your assertions, then "look over there a bunny".
If you search, you can find papers that describe exactly that, coating things in oleophylic coatings, to prevent adhesion. It's new stuff, not thick oil in an SBC or any other engine made in the last 100 years.
Would link you up, but then I'd be accused of only posting other's works.
There is a post long ago from someone who sounded like a research engineer. He was talking about the reptiling effect of molecules right before boundary conditions that caused a synthetic to act like a higher grade.
Its not like no one agrees with me.
Linkage ?
Are you talking about the pressure/viscosity effect at the extreme of EHD ?
Or something else ?
I wish you'd think outside the box a little more. That's how new things are invented.
Given that I'm the only bloke in Oz (reputedly further than that) to have developed a method of replacing snapped turbine blades with finger an pin roots without taking the rotors out, and developed an inconel welded cover band repair that didn't require PWHT, I'm doing OK with headspace and boxes without having to make up unicorn effects.
Linkage ?
Or something else ?
