I have an Audi a8 with tiptronic gearbox (zf 6hp26) which had torque converter shudder. I updated the software and changed to the green atf used in Zf8hp gearbox and that problem is solved.
However, once I have changed the atf, I have a jerk shift from 1 to 2 and from 3 to 2 always when hot. When cold it is fine. Now in summer the shift is still worst.
I have been thinking in using lubegard atf protectant (red) which seems to be good for heat problems. I'm also thinking in improving the atf cooling, but don't know how to perform it. It has a small cooler which uses engine coolant.
Do you have any ideas or possible solutions for this problem?
Thanks
Thanks
