Two quick thoughts: First, this is a three-year-old thread.
Second, up until 2012 or so, Honda owner's manuals included a fairly complete specifications section. Among the specs was one for the total engine oil capacity, in addition to the usual oil-change amount with or without a filter change. The total oil capacity was (and likely still is) roughly 9/10th of a quart more than the oil-change amount, with or without filter.
So, if you are one of the obsessive/compulsive types who not only jacks up your Honda to change the oil but also, deliberately or incidentally, lifts one side of your car higher than the other to get just that much more oil to drain out, you're going to end up adding more than 4.2 or 4.4 quarts.
