Originally Posted By: Danh
Maybe, despite claims to the contrary, you can't have great filtration and great flow at the same time.
Sure you can, this subject has been discussed many times. If an oil filter is designed correctly you can have both good flow and high efficiency. Don't forget how a positive displacement oil pump works ... they don't really care if an oil filter has a few more PSI of delta-p across the media when oil is being forced through it by the PD pump.
