Consider running Redline 5W20 or 5W30 twice then doing a UOA or Amsoil 5W30 HD and doing a UOA.
All Toyota engines generate low wear number's. Insolubles and oil consumption are the only issues any Toyota's ever have with oil. If oil consumption is not an issue with 5W20 and wear numbers are good you have no need explore other grades unless you just want too!
Everyone I know for instance that owns a 2AZ-FE engine all have no oil consumption issues at all. None of them have ever ran a 0W20 or 5W20 oil. All of them run a synthetic 5W30,10W30,5W40 or 0W40. All of the reports online on this engine and oil consumption issues all seem to be related to owners that have run either 5W20 or 0W20 exclusively.
On the other hand I know plenty of people with Honda, Ford and GM vehicles that have had no issues at all with 5W20 or 0W20 even when not recommended for that year make and model of engine.
I think UOA and observation might be more important then OEM recommendation by country. It would be different if the recommended oil weight/grade was universal but it varies by country so what is recommended is not that big a deal.
