How much oil consumption is expected from a bad PCV valve? This car has never needed oil added between oil changes but recently was over a quart low when I checked the stick. Pulled the PCV valve and was clogged with oil along with oil in the hose. Replaced with new OEM valve but wondering if I have other issues. Car has 170K and replaced plugs about 5K ago. Doesn't smoke or leak any oil. Power seems good although mpg was down to 30 mpg from usually 33 mpg. I did use a different brand 5-20 oil on last change. I have used QS Defy, Penzoil Platinum, Valvoline and Havoline over the years and used Peak Conventional the last time but didn't think that would make much difference in consumption.
