I found oil around the bolts in the holes indicated in the picture below. It happened when there were 20% to 30% oil life left. I checked oil level is within normal range, and there were no other problems found. What might have caused the problem? Is it possible that it's running lean with a custom tune?
[img:center]https://www.dropbox.com/s/ixa0bpyzhb07ouf/1.jpg?dl=0[/img]
