Originally Posted By: Whimsey
Originally Posted By: Trav
Originally Posted By: dlundblad
This reminds me of the tick my jeep developed while using Mobil 1 filters. I assume it turned out to be the lifters.
A tick lasting as long as you say has to be mechanical and not filter related, but then again, it sure is ironic is started the next day..
Most of the ticking is gone within a few seconds but if you listen closely you can hear faint ticking sounds for a few minutes. Most people wouldn't even notice them after the first few seconds but i do.
I know that engine like i know the back of my hand inside and out. The slightest difference in sound, vibration or running is noticed right away.
The sound did start right after putting that filter on, so we will see.
Could be a coincidence about the filter. Weak ADBV usually only cause initial start up noises I believe. It almost sounds like an exhaust leak tick that eventually quiets when the leaky parts warm up enough to seal the exhaust leak. I have that on my 1996 Contour Zetec, the colder temp it is at start up the longer the exhaust tick. Just a suggestion
Whimsey
This is my own car, there is no exhaust manifold leak, i would know that in a minute but yes your right it can give a similar sound. The noise is 100% lifter noise.
New filter is on so tomorrow AM i will know.
