2001 Dodge ram 2500 4x4 Cummins. Dana 60 up front and Dana 80 limited slip in the back. 6 speed manual NV5600 transmission. 3.54 gears. 262k on the clock
Fluids:
Engine: Amsoil premium diesel changed every 7-10k
Gearbox: Redline 5w-30
Power steering: Royal purple synthetic PSF
Front differential: Amsoil Severe Duty 75w-110 changed 30k ago (has mag-hytec extended cover)
Rear differential: Amsoil Severe Duty 75w-140 changed 30k ago (has mag-hytec extended cover)
Truck has meaty 35" tires with the 3.54 gears and I tow
Fluid needs changed ASAP. Ive been launching boats in flooded areas and both diffs show signs of contamination. I have not had one single axle problem since I got the truck 250k miles ago, but it spends a lot of time on the boat ramp and off road. If it makes any difference the truck is heavily modified from stock.
Anybody like anything better than the amsoil gear oil?
Fluids:
