I recently picked up a welder/generator powered by a Honda GX620. It's electric start. If I pour some gas into the carburetor, it will start, and run until the gas dries up. I've done this enough times that it should run if it's going to. It has two fuel filters, the lower one definitely flows, and the upper one looks good (they're clear), but I haven't disconnected it yet.
After I check the upper fuel filter (which I'm sure is good), then what?
