I picked up a Morse high speed steel cutting tap at the industrial supply today. The size is M8-1.25.
For some strange reason, when I spin an M8-1.25 nut on the tap, the nut will stop at the last 3 threads.
I tried this with two identical GM flange nuts and two identical Rockford flange nuts from NAPA and they all stop at the last 3 threads. Meanwhile, I experimented with a Vermont American hardware store tap in the size 3/8-24 and the nut spins all the way past the last 3 threads no problem.
