mikeinaustin
Thread starter
Originally Posted By: TFB1
Originally Posted By: mikeinaustin
and that is my point, it seems to me that this failure point number must be published somewhere. i thought it was called the discard value, but am not sure anymore.
Minimum and discard are one in same(well discard is .001" less in thickness than minimum)... As far as failure point depending on load, towing, etc it could vary on same vehicle... Mostly it's a safe point the rotor can still dissipate heat, and not a strength issue...
yes well in my particular case the stamped minimum is 22.4 and bmw measures the rotor at 21.5, so i am 0.9 mm below the minimum.
