I'd probably start advertising. My car took a while to sell--not as rare as I hoped for.
I picked up one of these last year, and installed onto an old WinXP laptop:
http://www.amazon.com/gp/product/B00C9B3...ailpage_o07_s00
Connected to both of my yodas. Says it will work back to 1996.
But in your case, since stuff does not rot, you could go back to OBDI. I toy with that myself, to get out of the emissions check; but I'm not sure I can give up the "security" of side airbags etc. And I would have to fly a long ways to find one not eaten up by rust.
Question on the ABS issue: wouldn't ABS be a rare option on these models? Also, did they use EBD? I am thinking no, so if the ABS system was broke it should bot matter. I can pass inspection with an abs light (can do so with an airbag light too), but my prior car had EBD and thus I suspect it would be a bad thing to drive around much a fault (rear brakes apt to lock up quickly under hard braking).
