Radiator good , no leaks. Car does not overheat. 50/50 mix. does not use coolant. No coolant in oil. If I check the coolant tank when engine is hot I see foaming in the space between coolant and lid. Foaming goes away when cools down. Coolant about 2 years old, the all vehicle green kind. Any ideas as to the possible cause? Oh, car is a 1994 saturn sl2 with over 200,000 miles but runs great with only burning some oil, 1 qt in about 1500 miles, more if I run 70 + mph on short trips.
