I have a question for any transmission guys on here. I have a 2006 Toyota Tacoma V6 and it was due to have a transmission service done. I normally perform my own service but I was pressed for time so I took it to a local independent transmission shop to be serviced. The ATF fluid that Toyota requires for this in this transmission is Toyota WS ATF.
I know there are several aftermarket brands that are compatible with Toyota WS ATF but they used Penzoil Multi Vehicle ATF. The spec sheet does NOT list Toyota WS as a suitable fluid application. Here is the spec sheet. http://www.pennzoil.com/wp-content/uploa..._1_11_FINAL.pdf
I've driven a few thousand miles before I noticed the discrepancy, and the transmission is working fine. I have purchased enough Valvoline Maxlife ATF to do an entire system flush and will be changing it out myself this afternoon. It IS Toyota WS compatible. Here is the spec sheet on Valvoline Maxlife ATF. http://www.valvoline.com/pdf/maxlife_atf.pdf
My question is this, do you think any damage may have occurred in a few thousand miles of running the wrong ATF or do you think I'm being too OCD about the whole thing?
Thanks!
Thanks!
