Going to try CarPro Hydro2
NorthEast
Finally broke down and ordered this "Miracle-in-Bottle" concentrated snake oil! I had always wanted to try this product since it came out first. For somebody lazy like me, this seems to be a godsend one.
Wish me luck.
Some tips:
1) never use in the sun
2) spray one panel at a time, make sure the panel is covered in a fine mist. Don't rely on water to spread the product.
3) after rinsing, re-rinse any areas that the run-off may have contacted (I.e. If you do the roof, re-rinse all of the doors and glass)
4) maximum slickness may take a few hours to develop, and yes, it bonds best to bare paint.
It's a great product, but the water conditions no longer allow me to use it out here.
How does this compare to Opti-Seal? Opti-Seal lasts 6 months vs 3 months for this product.
Is the Hydro2 more repellent?
I've never seen Opti-Seal last 6 months. I usually see 2-3 mo depending on the number of washes and whether the vehicle is garaged.
Hydro2 lasts about the same for me as Opti-Seal. Hydro2 beads and repels dirt a lot better. But opti-seal costs a fraction of what Hydro2 costs...per vehicle. It's like 80 cents a car versus $4.
Thanks.
Sounds like the permanent coatings might be more time and cost efficient.
Which one of those is your favorite at the moment?
Agreed on all accounts, as usual.
IME, HydrO2 makes the surface way more hydrophobic than Opti Seal.
Meh; too expensive for what it does. I did not even manage to do 1.5 cars with the $20 chemical. I had to do it outside and with the breeze, half of the product was not landing on the vehicle. I could not do this inside the garage because the inside of my garage is not "waterproof"!
Even if the bottle had cost me $2.00, I would have been still disappointed.
Well, at least it finally got out of my system and it was worth $20 to learn a lesson.
The wind is definitely not your friend when applying it.
When you say the "$20 chemical", I assume you mean the 100 ml size as it is a little less than $20.
You mix it 1:3 with water, so the 100 ml size turns in to 400 ml of product. It takes approximately 40 ml to do a car, so that size should be good for 10 cars. That means that each application should cost approximately $2.
I used way too much the first time that I used it, but got a much better feel for it the second time. A really fine mist sprayer makes the application a lot easier.
As you mentioned, I don't even bother if it's windy out. I don't want the mess in the garage, so I don't use it in there.
400 ml sounds a lot but it does not even make the 1/4 of the standard size chemical resistant spray .bottles such as Meguiars Detailers Choice. I had kept the spray size as low as I could.
I use the 8 oz. sprayer bottles from Detailed Image. Mix with distilled water and then spray away. The tips that The Critic listed earlier are what I've discovered as well. I missed a few run-off spots the first time I used Hydro2 - the side mirrors still have the spots several months later.
I confess to using Hydro2 on the minivan. On the MDX, I've been experimenting with CarPro Reload and Optimum Car Wax. From a durability perspective, the CarPro products are much better, but Optimum Car Wax seems to add a different "warmer" look to the paint.
Those bottles do not deliver a fine-enough spray for Hydro2.
I usually use 4-5 oz per car (being generous), so 400ml should be more than enough for 2 cars.
