Originally Posted By: OpenClose
OK, so to be sure, I am unplugging the tube indicated in red from either end, and this will disable the boost bypass valve, correct?
Will this create a heat problem? I hear something like this can create problems in the low-end of the RPM range.
Yes, red circled hose. No it won't create any problems. What that does is disables the computer from limiting boost when traction control is activated, top speed limiter activated, and limits to 30% maximum boost in reverse.
You are only disabling the boost control solenoid by allowing the boost bypass valve no computer intervention.
