Originally Posted By: abycat
No a 2 stroke has a higher Rev limit and makes most power at high revs. Both tq and hp. a 4 stroke makes its power at a much lower rpm. 2 strokes make more power with a smaller displacement than a 4.
From a technical point of view, high performance 2 strokes typically do not redline at as high an RPM as a typical modern 4 stroke. The examples are to numerous to list.
One good example for technology comparison is a 250cc motocross or Kart engine. As produced, the 2 stroke runs to 9500 RPM and the comparable (albeit less powerful) 4 stroke runs to 13,500 RPM.
In race trim, a well prepped, modded 250 2t will run to 10,500, but torque drops off sharply starting at 8500.
Whereas, a stock 450 4t will run to 11,500, considerably higher than a race 250 2t.
