Originally Posted By: TFB1
If it's electric, the condenser/radiator fan(s) will activate anytime A/C is on, so in theory A/C should be as good idling as moving(that's case for both my Grand Marquis)...
The variable still at play is actual A/C compressor output. One moving at 600 RPM engine speed won't pump as much refrigerant as one moving at 2,000 RPM engine speed. This will, naturally, vary with vehicle, compressor design, etc.
For example, I can't tell a difference in vent temperature in our Acura regarding idling or moving. But I can tell a difference in our CR-V -- it does feel a touch warmer slowing to a stop (when the engine is already at idle) and sitting at a traffic signal. Just a few seconds after I move off the light, and the engine speed rises, the vent temperature becomes slightly cooler again.
