My 2003 Ford Escape Limited has started making some front disc brake noise (either a high pitched squeal or deep rubbing noise) and this all started after I had the following parts installed:
Dorman Control Arms
Monroe Quick struts (Front)
Monroe OE Spectrum Shocks (rear)
Moog Coil Springs (rear)
The brakes that were on before the work was done were Wagner Thermo Quiet pads with Wearever Rotors with around 15,000 miles on them and never made any noise. To attempt to correct the noise I have completely disassembled the disc brakes, cleaned everything thoroughly, lubricated the pins and all contact points, and even did a warranty swap on the pads and rotors to see if it would make a difference. The noises are still there. My cousin (experienced mechanic) performed the suspension work and will be going over everything with me this weekend to see what the issue could be. I find it extremely weird that all of this noise only started happening after the control arm and strut work and hasn't responded to cleaning, lubrication, and pad/rotor replacement. Does anyone know if the control arms or struts could be causing this noise and how? Maybe any other ideas on what else to inspect?
Thank you very much to anyone who takes the time to read this and/or offers advice.
PS - I have attached a picture from today when I noticed some odd rotor wear. Seems like the inner rotor is not making contact with the pad. I replaced the long outer clips today with Wearever and the noises remain.
http://postimg.org/image/ds3k3ghkv/
Dorman Control Arms
