I just replaced the boom/shaft on an older Homelite string trimmer with a factory replacement, sadly I didnt find the local parts/service dealer on the Internet first. Part number is 000998229
After running it for about an hour the bearing end got very hot. A week later I removed the string assembly etc, and even with nothing loading it down, it got quite hot after less then a couple minutes of running.
Was I suppose to lube/oil/??? it before use ? I could find nothing on the Internet other then just take-apart-lube the cable- put back together.
