I dropped the pan on my moms 02 Windstar. No exaggeration, the magnet had at least 1/2" metal sludge build up on it. After I cleaned it off it was only half the size it looked like with the build up. The fluid in the pan was a slush of very dark purple.it didnt smell burnt but definatley didnt smell like atf. Actually smelled closer to motor oil then anything else.
I was just gonna replace the 4 qts suggested capacity of the pan and change the filter. 6 qts drained Out. I had an incorrect filter so I just put the pan back on for over night with filter off. Next day got correct filter. It had drained about 3 more qts over night. so I ended up replacing 9 of 12.25 qts.
My worry is that all that new fluid will clean the sludge around clutch packs and the the clutches will have nothing to grab hold of and will just slip if they are too worn down
I did notice that the fluid that drained to the pan over night was not full of so much mettal debris like the fluid in the pan. It's my hope that the majority of the metal was trapped in the pan and not so much In the rest of the unit.
