The car is a 1999 Saturn SL2. Mileage 254,777.
Two parts failed. "Both rear stab. links worn allowing excessive bar movement. Rear sway bar bushings worn allowing excess bar movement".
Asking around $225.00 to do all repairs. Said I could go somewhere else. Somewhere is Me.
So Rock Auto had Moog Stabilizer Links $24.00 a pair. It is probably good to replace the links since they can break. I hit something in the rode that blew out my left rear tire recently. So it may be a blessing in disguise that the links were flagged.
After research I do not want to mess with the sway bar bushings. I have limited use of my shoulder and limited tools. They are set replace those for $97.00 on Tuesday.
Here is where I have questions or doubts. I went to remove left rear wheel to replace the links. Could not get any of the lug nuts to budge, even with a breaker bar. I torque them to 100 lbs. I rotate my own tires.
So I call the Service Station/Shop. Talked to the Manager. They will remove the wheel so I can change my links. I was told they do not use anything to torque the lug nuts. No torque sticks. No torque wrench. Manager: "We use an impact gun. Have not had a problem for...2 years."
I did not know you could fail inspection due to sway bar bushings?
Was this a slow day? Need to generate some revenue? It seems like this is being picky, but my level of knowledge does not allow me determine that.
At this point I don't have a lot of confidence in this shop. My time is limited. Not sure other shops will be better. Plus, they need check the parts after replacement for me to pass inspection. Not sure that involves removing the back wheel again but I do have my torque wrench in my trunk and plan to not leave the shop until the wheel is torqued properly. After that I plan to never go back for a safety inspection or refer friends to this shop.
