Originally Posted By: bbhero
I am telling you .. From my experience... It's not near the top of things I am concerned about.. Period. If a transmission has issues... You can change that fluid every 20,000 miles.. It won't matter. Why?? Because the problem is mechanical.. Not related to fluid. I KNEW my mom and step fathers 99 Expedition was going to have tranny issues. Why?? That darn thing had GREAT difficulty with being in the correct gear in the 35 to 50 mph zone.. Shift up ..down..up..down ..up again. It blew up at 125,000 miles. Fluid wasn't the problemo. . it was a very poor mechanical design.. Let's ask this pertinent question.... Why are the 2013, 2014 Altima cars having transmission problems??? It has ZERO to do with fluid not being changed... Mechanical issues and quality control problems with JATCO. Here's another interesting fact.. My generation of CVT is far better with reliability than the newer ones... Mechanical... Not FLUID problems. I
I am going to change my CVT fluid
I do not say there is nothing wrong with changing your trans fluid q 30 to 60k miles..that's fine
I will likely change my fluid in three drain and fills from the transmission starting at maybe 120k.. I have 110k now.. I do agree that these CVTs are a bit of an different animal.. But again, my experience has been over a half million miles that it really the biggest concern.
I would also add that if someone lived in the southwest US or southern US with regular hot ambient temps greater than 95° it would be wise to change CVT fluid on a scheduled 60k to 75k ... That kind of heat is a consideration. Where I'm at.. Only 4 months out if the year does it even have the chance to get that hot.
Also... My manual says to inspect it in the schedule 1 or 2 maintainance schedules. The only caveat is if you are hauling a trailer, luggage rack, and or drive in very dusty areas. None of which I do.
I also don't trust the Nissan dealership to tell me truth about the scan results unless I could watch the results first hand.. Them chickenheads tried telling me to change valve cover gaskets even though there is ZERO leaks or anything when I asked about changing my spark plugs.... Non sense. These fluids are FAR better than they were 15, 20 years ago.... Thus why a number of manufactors don't even suggest changing the fluid. Ever.
Now again, I am going to start to change mine at 120k.. Going to do three drain and fills from the main case over time.
Congratulations on your luck so far, but your experiences are incredibly narrow and are in no way sufficient to scientifically determine your transmission will be reliable for the long haul.
You said yourself you have 110k on your current CVT, what if it goes kaboom at 111k? We wont really know until you and millions of other examples of owners reaching well past 200k+ to have enough examples to determine reliability. Otherwise we have very few statistics to judge by.
Cheers
