Interesting that the owners manual recommends 89 octane for the 5.7 Hemi but 87 for the bigger engine. It does mention knocking so I would have to assume that might have something to do with it but it also states that premium will offer no benefit over regular gas so I don't understand why 89 octane would either.
FUEL REQUIREMENTS
3.6L/6.4L Engine
These engines are designed to meet all
emissions regulations and provide excellent
fuel economy and performance when
using high quality unleaded “regular”
gasoline having an octane rating of 87. The
use of premium gasoline is not recommended, as it will
not provide any benefit over regular gasoline in these
engines.
5.7L Engines
This engine is designed to meet all emissions
regulations and provide satisfactory
fuel economy and performance when using
high quality unleaded gasoline having
an octane range of 87 to 89. The manufacturer
recommends the use of 89 octane for optimum
performance. The use of premium gasoline is not recommended,
as it will not provide any benefit over regular
gasoline in these engines.
Light spark knock at low engine speeds is not harmful to
your engine. However, continued heavy spark knock at
high speeds can cause damage and immediate service is
required. Poor quality gasoline can cause problems such
as hard starting, stalling, and hesitations. If you experience
these symptoms, try another brand of gasoline
before considering service for the vehicle.
FUEL REQUIREMENTS
3.6L/6.4L Engine
engines.
5.7L Engines
