Originally Posted By: DutchBrad
Update - this car is up to 222,350 miles. Still does not idle, but just keeps on running. So glad I bought this car, it is fun to drive.
Don't be so surprised the electronics work fine, it's a 5th gen Honda...
I have an Accord of the same vintage with around 270K and the same engine. Your idle problems are caused either by the Idle Control Valve (ICV) located on the back of the intake next to the fire wall, or the Fast Idle Thermo Valve (FITV) located below the throttle body on the intake manifold.
Take them both off, clean all the carbon out of them with CRC carb cleaner, make sure the 3/8 coolant hoses going to them arent plugged up with sediment, and put them back on with new gaskets. THese have everything to do with your idle speed... there is also a brass idle adjustment screw on the throttle body to fine tune once these are clean.
These get carboned up from the PCV system blowing oil into the intake. Also pop your EGR cover plate off the top of the intake runners and clean the carbon out of the passages and ports while you are at it.
God luck, let me know if you have any questions.
