My SV1000s gave me little notice when the flywheel magnets disintegrated. I heard a slight squeak that lasted about a second. Otherwise it ran fine. About half way home (7 miles) the engine started ticking quite loudly and this was the result.
I drained the sump and did not find any magnet bits in the sump (you can see the entire sump from the flywheel side) And the magnetic drain plug just had a touch of fuzz on it. I hope for the best!
Rumor has it that the magnetic bits tend to clump together and remain by the flywheel. This is a common problem and I have not heard of any ruined engines. Even so, I'm partially disassembling the engine to ensure parts are clean. If I find disaster, I'll simply purchase a replacement engine. If not, I'll clean it up and perform a number of oil changes.
