Mostly highway miles. 5qts of makeup oil added over 11k miles (has burned a quart every 2k since motor was new).
Iron trending up. I had the HPFP lifter and exhaust cam replaced at 160k. They are a known issue with these engines, they wear and start short stroking the fuel pump and you get low fuel pressure codes. I wonder if it is "breaking in" still?
Previous oil change was GC 0w-30, and the ones from 2010 were Rotella T6 5W-40
