Doesn't the factory filters operate this way anyhow whenever oil pressure is above the bypass valve setting? For example (and only example because this is two different vehicles), the oil pressure in our Oldsmobile is almost always over 35psi except when warm/hot idle in drive (dips into low teens). Now, I don't know if/what the bypass is on that car since it uses a cartridge filter, but take for example the Motorcraft filter for my old Mustang (FL-820S), didn't that have a bypass pressure in the teens?
I'm probably misunderstanding this, but?
