I had a low oil pressure sensor failure last year and replaced the sensor that screws into the lower block. However, lately I noticed something odd.
In the mornings the warning comes on for 1 second ,as soon as the car starts it goes away, which is normal.
After say a 1hr drive, I stop for a few minutes, then restart the car, the warning doesn't even light up.
Is this normal because there is residual pressure in the block..or is the warning supposed to light up every time right before the engine turns over ?
