Sort of long, but here’s the story.
Three years ago we purchased our van from an acquaintance. At the time of the purchase, they said they had a recent brake job done by a known and trusted shop in our area. Before the purchase, we also had a certified mechanic inspect the vehicle. He said the brakes looked good, newer.
But from the beginning, we noticed a noise coming from the front driver side. The best way I can explain this noise is a brushing sound with each revolution of the wheel that would go faster and eventually fade away as the speed increased. Not too noticeable with the windows up but well apparent with the windows down. With newer brakes installed by a professional, I assumed from the beginning, the sound wasn’t coming from the brakes. I eventually had a front end inspection done by a tire shop. I asked them to check the wheel bearings also. They said everything looked fine.
More recently, a new sound started in. I would liken this sound to dull gritty metallic grind when the brakes were applied. So I pulled the front driver side wheel and inspected the brakes. First, I found a fairly significant groove worn into the outer brake surface of the rotor. Next I noticed a concentration of what looked like metallic material on the corresponding part of the Raybestos brake pad. The passenger side never made a noticeable noise nor had any significant grooves worn into the rotor. This is when I began to wonder if I got a faulty brake pad and if this was to source of my noise all along?
Yesterday, I installed a new set of rotors and a different brand of brake pads. I’m amazed at how quite the vehicle sounds now.
So, should I call Raybestos to see if it’s something they want to look into? Would you contact them? Or should I just let it be?
