So, why do BMW N52 engines have leaky gaskets? Oil filter housing, valve cover and oil pan gaskets all seem to have short life spans. I have had two of these vehicles, and both between 60-90k have had to have a combination of these gaskets replaced. The 2008 E92 had the valve cover gasket replaced at 48k. Both fed a steady diet of approved BMW oils at less than the absurdly long BMW OCI. Typically 5-7k intervals. Is it material related, temp related, or crankcase pressure related? Design or assembly related? Or is it something else? Liqu-moly motor oil saver slows it down, and does seem to postpone the repair, but does not seem to be the cure. I am looking for any insight as to what the cause is. Do I double the dose of LM motor oil saver after a couple of years and/or 40K?
